Remove empty images from report
1921
03-22-2024 03:19 AM
BenBlowers2
I have a survey which asks lots of questions and lots of photos can be taken (multiline so more than 1 photo can be submitted for each question).
When the report is produced from Survey123, if a photo was not taken, it displays an empty thumbnail, like in the 1st attached screenshot.
What syntax can I use to only display the image question answer if an image was actually taken?
I tried:
${#AIC_BuildingFloorplansImage}${if $file | size:0:0:0:250}${/}${/}
But this did not work - no images were returned yet Survey123 could not detect any errors with the syntax when saving the report template.
Thank you,
Ben
ArielRetuta
Have you found or received a solution for this? I am having the exact same issue and it's driving me nuts!
ArielRetuta
I was able to make this work with the following:
{#image}
${if $file}
${$file|getValue:""|size:150:0}
Apologies for the weird spacing, this is my first time posting a solution (yay!). Hope it helps.
