Relevance Help! Survey 123
1120
03-15-2019 03:41 PM
Wade_Adams
I have a question about a simple survey I am working on. My issue is with one field called ${WR_Fail} I am trying to hide this until the result of the previous question ${WR_Pass} does not meet the requirement. So after I input the numbers on the survey, if it does not (pass) I want fail to (show) right now (fail) is always showing because (pass) automatically does not meet the requirement. I have attached the xlsx. Any Ideas would be greatly appreciated!
JohnathanHasthorpe
Hi Wade
The issue is that the required statement is: ${WR_Pass}<35 or ${WR_Background}<7
But ${WR_Pass} and {WR_Background} are both note (text) fields.
The evaluation is failing because you can't do < on a string.
Thanks
John
