Question on Editing Data on Survey123 Website
1093
05-15-2019 06:45 AM
AntonioGarcia
Hello,
I am a little stumped.  I am trying to edit data through the survey123 website, but when I try to click the "edit" tool, it doesn't allow me to access the tool to edit (SEE BELOW - when hovering over the tool it states, "Editing existing records is not currently supported for surveys published with Survey123 Connect").  Does this mean I cannot edit data through this window at all or is this a feature that can be turned on or off?
Any help would be appreciated.
KassandraRodriguez
That features are only editable if you made the survey through web not connect.
MikailaBell
I edit data in a map table. Arc Pro is best, but AGOL works too.
