Query non-spatial hosted table using Survey123 pulldata()
1469
08-12-2020 09:44 PM
AdrianDoss
I have the following use case:
I have a Survey123 form to record start-up checks on vehicles. When the user enters a vehicle ID, I want to query a separate non-spatial hosted table to pull vehicle details using pulldata() and javascript. There are examples on how to query a separate feature layer but can you query a hosted table?
by Anonymous User
Not applicable
Hi Adrian,
I believe you asked the same question here Query data from separate feature service in Survey123. If you are able to write the needed custom JavaScript function and access the data in that hosted table then it should work.
Regards,
Phil.
