Pulling lat/ long data from geopoint
8215
6
03-08-2017 01:42 PM
AlexisGieseker
I can pull data from the geopoint in the survey123 connect. However, it doesn't work in the app when submitting a survey. I have my form set up like this. I have also tried the hidden field with no luck.
decimalLatitudeLatitudepulldata("@geopoint", ${location}, "y")
decimalLongitudeLongitude
pulldata("@geopoint", ${location}, "x")
Tags (1)
IsmaelChivite
Esri Notable Contributor
Hi Alexis.  This is strange.  Would you please share your XLSFile and provide some details on the model of phone you are using?
DeenaBowman
I'm curious, do you receive an error message when you submit or are the fields empty?
LindseyDagnall
Alexis,  Did you ever find the solution to this? I am having the same problem.
Carolyn_Novak
I had  the same problem.  Deena I was having the problem when I submit.  It threw an error then.  I tried decimal as well and I could see it has the data but it still errored out on submit.  When I tested this calculation with  a test form and a Trimble R1 it worked just fine. I had a value in the accuracy Threshold column (T).  Once I removed that I was able to submit.
JamesTedrick
Esri Esteemed Contributor
Hi Craolyn,
What value did you have in the accuracyThreshold column?  I was able to submit with a sample threshold value of 20.
Carolyn_Novak
I had it set to 5.  That might have been the problem.  I went out and tested the app again and sometimes it worked and sometimes it threw the error.  I'm reviewing everything now on the desktop.
