Pulling deviceID and version properties in Survey123
1608
08-19-2019 04:58 AM
JamesKelly4
Why doesn't pulldata("@property",'deviceid') work in my Survey123 form? I know it is not supported in web form so I turned web form off. I am having the same issue with pulldata("@property",'version'). Both return a value of unknown. I have tested it with 2 different iOS devices. Any help is appreciated! Survey123‌ pulldata()‌ James Tedrick Survey123 Survey
JamesKelly4
Ok I figured out that deviceid is it's own question type. That part is working for me now. How about the version question though - is there a way to record the version of Survey123 used by the submitter? Survey123 for ArcGIS
JamesTedrick
Esri Esteemed Contributor
Hi James,
There is currently not a way to poll the version of the Survey123 app being used.  You may want to vote for it at https://community.esri.com/ideas/15198 , which helps us keep track of user interest.
