Pulling Data from Existing Feature Service Layer into Survey123 form
863
06-20-2022 01:12 PM
StevenJBlitzstein_PwCUS
Hello,
I want to create an inspection form off of an existing feature service layer. Within the survey, I want to pull already populated attribute data for my features into the form so when someone opens a form to perform an inspection on an existing asset, the information is already populated for them. Do these fields auto populate by default as long as my survey has been published using the feature service option in Survey123 Connect?  Can someone please advise me on the best way to do this? Is there a formula to enter into the calculation field?
Steven
ZacharySutherby
Hello @StevenJBlitzstein_PwCUS
If the data already exists in the feature service the survey is pointing to if you enable the Inbox when a record is opened from the Inbox all the information will be populated.
Thank you,
Zach
