Pulldata not Populating Repeat Fields? I have a survey that creates two csv one is for the first part of the survey which acts as kind of the header and I can pull data easily from it (I am using a number to ID each old survey for the pulldata function).
1087
12-13-2016 01:28 PM
JarrettTotton1
I have a survey that creates two csv one is for the first part of the survey which acts as kind of the header and I can pull data easily from it (I am using a number to ID each old survey for the pulldata function). The second part is a nested set of repeat questions (they are trees depends how many trees there are). I assumed it would pull the data into the repeat as easily as the header part but it doesn't work at all. I assumed it would create the same amount of repeats I had last time and fill them with last times data, and allow me to create new trees. What am I doing wrong why doesn't this work?
Tags (1)
