Proper syntax when using a answers to select_multiple question in Inbox query
1288
08-09-2024 01:14 PM
NevilleCTT
I have been trying to get the correct syntax to use the answer to a select multiple question in my inbox query. I am opening the survey that is created from another FS via the inbox for the dwelling survey.
 So the inbox query works when I say building_type = 1 however this will fail is the answer to building type is 1,2. I have tried using the IN and LIKE operators but these fail.
What can I use? additionally, is there a way to test this inbox query without republishing the survey?
Regards
Neville
abureaux
MVP Frequent Contributor
Have you tried %?
Will find "1" from a list:
More details here.
abureaux
Have you tried %?
More details here.
NevilleCTT
it worked, I had the quotes in the wrong place, inside the percentage signs
