Prevent scrolling when collapsing a group
1316
06-01-2018 09:20 AM
NicolasRoger
Sometimes, collapsing a group make the screen scroll up. The expected behavior I have is for the group title and arrow to always stay exactly where they were when I press the collapse button. Otherwise it is easy to get lost in the survey
The behavior doesn't always show itself, so I have attached a survey that show the problem. To reproduce, follow these steps:
1- Reveal the group "Test1"
2-Scroll down until the group header "Test1" is almost to the top of the page
3-Collapse the group "Test1"
4-You can see that your mouse pointer is no longer over the collapse button.
I have reproduced the behavior on Survey Connect and also on an Iphone.
Is there anything I can do to stop this from happening?
JohnathanHasthorpe
Hi Nicolas
This is a known bug - I'll add your information to the internal issue with have for it.
Unfortunately, there is no workaround for this.
Thanks
John
NicolasRoger
Thank you for your answer.
I would like to add that the same issue appear when showing a question controlled by a "relevant" field.
For exemple, unlocking a big select_one question when entering a certain value in a field above.
Again, the issue only appear when the field is almost to the top of the page.
