Please I want redesign my survey123 form being published by survey123 but I am finding it difficult.
1203
07-03-2017 11:43 PM
NDA-GISGhana
Please assist me address this as quick as possible because my field guys are waiting.
Is it possible to set error margin for the location coordinates as it is done in 'Collector for ArcGIS'
JohnathanHasthorpe
Hi - Your issue looks to be that you are trying to edit a survey that you created in the Survey123 Connect desktop application, but using the web form (Survey123.arcgis.com). This is not currently supported - you will need to make your changes back in Connect.
If you want to add a location horizontal accuracy threshold for any geo-points captured, you can enter a numerical value (the distance threshold) in the body::accuracyThreshold column in the survey's xlsformPlease see the following resource for more information: Geopoints—Survey123 for ArcGIS | ArcGIS
