Operation rolled back error
6289
11
11-21-2018 08:02 AM
JürgenBiendara1
Hello,
I get an "Operation rolled back" error with my survey. The survey was working in Connect version 3.0.127. Now I have updated to version 3.1.126, copied the survey and published it anew. The excerpt from the log file reads:
<15>1 2018-11-21T15:52:10Z DUROWA Survey123forArcGIS 32648 - [AppStudio@11205 category="qml" function="onSuccess" filename="XFormFeatureService.qml" line="726"] qml: applyEdits:errors: [
"code": 1003,
"description": "Operation rolled back.",
"tableId": 0
"code": 1000,
"description": "The INSERT statement conflicted with the FOREIGN KEY constraint \"REL_FK_service_c64e490357c146a98212a0ee53a91a7d_R_CRS_1\". The conflict occurred in database \"db_4886\", table \"user_4886.service_c64e490357c146a98212a0ee53a91a7d_R_TNK_TANK\", column 'globalid'.\r\nThe statement has been terminated.",
"tableId": 3
<15>1 2018-11-21T15:52:10Z DUROWA Survey123forArcGIS 32648 - [AppStudio@11205 category="qml" function="onFailed" filename="SubmitSurveysPage.qml" line="351"] qml: Feature service error: [
"code": 1003,
"tableId": 0
"code": 1000,
"tableId": 3
<15>1 2018-11-21T15:52:10Z DUROWA Survey123forArcGIS 32648 - [AppStudio@11205 category="qml" function="" filename="XFormsDatabase.qml" line="363"] qml: updateStatus: {
"rowsAffected": 1,
"insertId": "14",
"rows": {}
<15>1 2018-11-21T15:52:10Z DUROWA Survey123forArcGIS 32648 - [AppStudio@11205 category="qml" function="onFeatureServiceInfoChanged" filename="XFormFeatureService.qml" line="936"] qml: featureServiceInfo: null
<14>1 2018-11-21T15:52:10Z DUROWA Survey123forArcGIS 32648 - [AppStudio@11205 category="ArcGIS.AppFramework.Network"] ArcGIS.AppFramework.Network: NetworkNotifier: con: 66
<15>1 2018-11-21T15:52:10Z DUROWA Survey123forArcGIS 32648 - [AppStudio@11205 category="qml" function="update" filename="FilteredListModel.qml" line="62"] qml: Empty filterText
<12>1 2018-11-21T15:52:10Z DUROWA Survey123forArcGIS 32648 - [AppStudio@11205 category="default" filename="XFormWebhooks.qml" line="102"] qrc:/qml/XForms/XFormWebhooks.qml:102: TypeError: Cannot read property 'itemId' of null
<15>1 2018-11-21T15:52:13Z DUROWA Survey123forArcGIS 32648 - [AppStudio@11205 category="qml" function="editSubmitError" filename="SurveysListPage.qml" line="622"] qml: error: {
"code": 1003,
"tableId": 0
<15>1 2018-11-21T15:52:27Z DUROWA Survey123forArcGIS 32648 - [AppStudio@11205 category="qml" function="expression for onStateChanged" filename="Portal.qml" line="214"] qml: Application state changed: 2
Can someone hint to where might be the problem?
Thank you very much, best regards,
Jürgen
Tags (1)
JohnathanHasthorpe
Can you share the survey .xls you used to publish the survey?  Thanks
JürgenBiendara1
Hi Jonathan,
There is a difference in the behavior of the survey depending on if I use it in my local ArcGIS Enterprise environment or if I use it in our AGOL environment. I can publish the survey in both and I can successfully send data with the desktop version of Survey123 (3.1.158) to my local environment. The "operation rolled back" error only appears in the AGOL environment.
Please find the xls file and the debug log attached.
Best regards,
Jürgen
JohnathanHasthorpe
Hi Jurgen - can you confirm the version of Connect you are using? This looks to be a related to a bug that existed in an older version of the application.
Thanks
John
JürgenBiendara1
Hi Johnathan - I've just upgraded Connect to version 3.1.126.
Regards,
Jürgen
JohnathanHasthorpe
Can you try to re-publish the survey in 3.1.126 and retest? If the issue persists can you share the created service with me via a group: jhasthorpe_survey123. I can't repro this issue using your survey, so would like to see if there are any differences.
Thanks
John
JürgenBiendara1
Hi Johnathan,
The latest results were already the Connect 3.1.126 results. Another test rendered the same results. It's working with my local ArcGIS Enterprise and fails in our AGOL environment. You now should have access to the "ROSEN Tank AGOL" survey.
Best regards,
Jürgen
JohnathanHasthorpe
Hi Jürgen
This cause of the issue looks to be related to the fact that your nested repeats have been nested in groups.
Removing the groups and republishing resolves the submission error.
I have raised a bug to a get this looked at.
Thanks
John
JürgenBiendara1
Thank you very much, Johnathan, for the analysis. I can verify that removing the group elements from around the repeats solves the submission issue.
Let's see what development says. I, for my part, am convinced that this combination of repeats and groups (which works fine in an ArcGIS Enterprise environment) is indispensable for a well structured and clearly laid out survey and should also work in AGOL.
Best regards,
Jürgen
by Anonymous User
Not applicable
Hi Jurgen,
Just an update to let you know that we have been working on the issues described in this post and a lot of progress has been made with repeats/nested repeats and defaults/calculations/relevants/groups and missing values when opening the survey, so we believe the issue has been resolved for our upcoming 3.2 release which is due end of January.
If you have time, can you please check out the latest 3.2 RC builds (Connect 3.2.192 and App 3.2.262) available on EAC here: Welcome to our Feedback Community and provide any feedback. The sooner we can get feedback the sooner we can address any outstanding issues before the release.
Regards,
Phil.
