Multiple geoshape questions, preload second geoshape map with previous polygon
1524
12-11-2021 11:19 AM
mattkramer
I have a survey that records data on a site.  A portion of that data includes areas of interest within the site.  I have my survey set up with a repeat to allow for 2 geoshape questions to be present, but the second geoshape question is completely independent of the first.  It would be very helpful to preload the map in this second question with the polygon from the first geoshape question.  Is this possible?
IsmaelChivite
Esri Notable Contributor
Hi @mattkramer  I do not think this is possible.  You can add into a map in your form all previously added geopoints within a repeat. See the Point overlays on maps section at: https://doc.arcgis.com/en/survey123/desktop/create-surveys/esricustomcolumns.htm   But the above, as of 3.13, does not work with polygons.
IsmaelChivite
mattkramer
I appreciate the response, thank you!  I think providing the user with a centroid of the first geoshape will allow them to quickly find the location and that should be fine.  Just wanted to make sure I wasn't missing anything.
