Map not functioning on webform
10335
29
07-23-2017 09:36 AM
ICFAdmin
I've created a reporting form to use on a website and it seems to work pretty well. Except, I cannot get the geopoint to collect data. When I try it on my phone using the app it works fine. I can move the location of the map after it automatically finds my current location so I can put it on the location I want to record. However, on the webform, the map does not seem to record the new location.
For example, when I move the map to a new location, I see no corresponding change in the latitude or longitude. Also, if I use the search box to "jump to" a location, the map does not update.
I tried just moving the map to a location and hoped it was recording the location even though it was not showing it. In the end, the map put the point in my default location and not the location I choose with the map.
Here is a link to the form:
https://survey123.arcgis.com/share/86cfaa95ffe74bc4925f537a2364ca1f
I've tried in Google Chrome, Microsoft Edge, and IE and have the same results in all.
I don't think there is much I can do from my end - it appears to be a programming issue. I would be happy to rebuild the form if that will help.
JamesTedrick
Esri Esteemed Contributor
If the survey was created initially before 2.3, then it is using an earlier version of the template.  For example, older surveys will have less of the configuration options available since they were not present when created; they can be easily added into the spreadsheet as described above.
ScottKiley
We rebuilt the survey using the current configurations, but maybe we did something wrong. Is there a way to tell which version a form was built with? I've confirmed that hide-input is available in appearances type when creating a new form, so that's good.
ScottKiley
Now the web-client is showing greyed out text entry controls underneath all our note types.
https://survey123.arcgis.com/webclient/8e2ee100f108432ebd569adb402e3f82
And we get an error when submitting the form:
   Cannot read property 'length' of undefined
JamesTedrick
The grey boxes are an issue that we're working on a fix for.  I am seeing the other error with your form and will log an issue to get it resolved.
ScottKiley
Thanks James. Also, do we have any control over the submitting survey page? Can we bypass it and go directly to a predefined page? Or at least go immediately back to a new survey.
JamesTedrick
Hi Scott,
Right now, we don't have additional capabilities in terms of after form submittal actions.  We plan to expand this in the future - aside from a new survey, what are the other actions you are considering?
ScottKiley
Basically, I want more control over what the users sees at that page. A bigger level html editor would be nice.
Scott Kiley, GISP
MSA Professional Services
JeffPowell1
Hello James, I am a colleague of Scott Kiley. Thank you so much for all these helpful workarounds, we are up and running with all of our desired changes. The final item needed before our deliverable is the issue of the grey boxes beneath all note fields described above. Any new update on this issue?
JamesTedrick
We have a fix going through testing currently and hope to implement it soon.
JeffPowell1
Hi James - just another quick follow up on the grey boxes issue. We have also experience a resurgence of the "unable to get property 'length'" issue described above although we haven't republished or altered the survey. Any updates? Also, will we need to perform any operation besides republishing the survey to take advantage of any ESRI solutions?
Thanks much!
