Make repeat required based on answer to another question.
1691
12-31-2020 06:12 PM
NDFAdmin
I have a need to require users to fill out a set of questions within a repeat based on the answer to a question outside of the repeat. Is this possible? I've tried using the relevant field and creating a constraint without any luck.
Thanks!
Aaron
by Anonymous User
Not applicable
Hi Aaron,
Yes it's possible to apply expressions in the Relevant column for repeats.
We should be able to apply the expression to the repeat as a whole (hiding the repeat) or questions within the repeat.  Here is more information on how to apply relevant expressions:
https://community.esri.com/t5/arcgis-survey123-blog/the-art-of-hiding/ba-p/898454
Constraints are a separate item, preventing users from submitting values unless the constraint is met.
If you're still encountering difficulty, can you please attach your XLSForm?
Cheers, Chris
DougBrowning
You need to use required.  A constraint to check for a blank value does not work.  So add the relevant then make the fields required.  If it is hidden it will not fire the required.
Hope that helps
