Losing repeat geopoints when refreshing into inbox of a survey
1009
01-16-2019 01:02 PM
MaazaMekuria
At present there is a way to copy the submitted data from the outbox into a new survey through the survey123 for ArcGIS app.  But would it also make sense to bring the survey with its related locations when importing existing surveys into the inbox?  I was expecting that geopoints within a repeat would be reimported ( it is blanked out) when refreshing the inbox of a survey123 for ArcGIS app.  The documentation seems to suggest that repeats will be returned after version 2.4 and one need only setup  allowUpdates=true to the bind:esri:parameters column in the survey form.  The used is survey version is 3.1.126.  Is there a way to selectively import existing data into the webapp version ?
It is efficient for us to bring back the original repeat geolocations so that date and time changes can be done quickly for using the same geographic locations.
Can we have a similar functionality in the webapp as well.
Thank you,
JamesTedrick
Esri Esteemed Contributor
Hi Maaza,
In addition to the allowUpdates=true, you need to also have the query keyword in the parameters column to specify the query to apply to the repeats.  The web app currently doe not support editing existing features.
