Location accuracy fields for laser offset points
714
07-11-2024 09:13 AM
NaturalSystemsDesign
I am preparing a Survey 123 form for high accuracy offset mapping. The equipment that I'm using includes an android tablet, Trimble DA2 receiver connected through Trimble mobile manager, and a TruPulse 360R rangefinder. I used the "Rangefinder Workflow Offset" sample available on Survey 123 Connect as a guide to set up the form. The form works well for mapping offset points (single shot), however the location accuracy fields that I added do not populate when the geopoint is taken using the rangefinder. If I open the form directly from my tablet (no rangefinder), the accuracy fields do populate correctly.
Is there a workaround to pull location accuracy values to a geopoint that is collected using a rangefinder? I understand that this won't capture error from the rangefinder, but it is important to record/create an accuracy warning threshold in the form for our GNSS receiver. Thank you!
