Issues with Embedding Survey into Experience for Editing
596
02-10-2026 08:30 AM
QuinnBukouricz
Hello.
I'm attempting to create an experience for our sewer cleaning crews. Basically I have fields in the feature class that will be filled out by a survey, which has been created in Survey123. I've created the survey directly from the feature class, and hidden all the fields they won't need to access. All the sync settings have been turned on.
I'm having issues with my survey showing "Editing is not possible because the globalId parameter was not provided." when displayed in Experience Builder.
The survey URL has "mode=edit&GlobalID={GlobalID}&version=latest" added to the end in order to enable editing, however it's not letting me edit. I know that it's case sensitive but I'm using what is displayed in the feature class as shown below.
I've followed all the steps based on the forum posts I've seen, and still cannot figure out what the issue is.
Any help would be appreciated.
DougBrowning
MVP Esteemed Contributor
Have you tried using the 123 ExB widget instead?
QuinnBukouricz
Didn't realize they added that integration, thank you!
lklun
Would definitely recommend using the S123 EB widget, it passes the global ID when you click on a feature on the map or in a table. I don't have the best luck with S123 URL parameters in embeds.
