Issues with appending existing data to survey feature layer
748
07-21-2020 08:55 AM
rymaaneliunas
I am appended existing data to my Survey123 form feature layer that I created online and I matched the fields but when I add a new point it doesn’t show in the web map because it is taking my Yes No answers as a different legend item.  So now I have two sets of yes/no items when it should continue to be only be one.  I am not sure what is happening. Thanks
JamesTedrick
Esri Esteemed Contributor
Hi Ryma,
Could you check to see if the field has a domain and that the domain codes match the name of the choice being submitted?  For instance, it is common to use the value 'yes' which differs from the value 'Yes'.
