ISSUE: Report Suddenly Not Generating
5544
12
02-26-2025 03:56 PM
cfransen
Just started getting this error today, even though nothing changed with the feature layer or the survey, won't even generate reports for surveys that had previously worked fine.  Has anyone else seen this issue?  The error is super weird and the spelling is off, it makes no sense.  Just started happening today but can't generate any reports either through Make.com or manually through the S123 dashboard.
Error when generating report:
"binde type esriFieldTypeDate for question start_time is not constist with feature layer field type esriFieldTypeString"
JodyZhengLiu
Great! Thank you for the confirmation!
JodyZhengLiu
Hi @cfransen, we have updated the Survey123 website with the fix.
AmandaPaton26
Hi @JodyZhengLiu , I seem to be having this same issue and it doesn't work in beta either. I'm getting a similar error message "Error: binde type esriAttachment for question sign is not constist with feature layer field type esriFieldTypeString" for an image question.
