Is it possible to embed a specific chart from Survey123 Results/Analyze in a Dashboard w/o Including Header?
1993
07-03-2023 10:24 AM
MatthewBrandt
Is it possible to embed a specific chart from Survey123 Results/Analyze in a Dashboard without including the header? I've tried to hide the header in the URL parameters, and I've retrieved specific element URLs from the "Inspect" feature -- but no luck with either of these. I've circled the area of the embed that I'd like to remove. I've already filtered to the specific question in the URL.
ChristopherCounsell
MVP Frequent Contributor
I mean... can you just remake the chart by adding the survey layer to ArcGIS Dashboards?
MatthewBrandt
Sorta -- I have a handful of questions using the rank type and select multiple, so I would need to create data expressions to show these charts in the same way that survey123 analyze tab does. I'm also hoping to show the word clouds for some questions which I do not believe is possible natively in dashboards.
