Internal server-side error
13922
28
07-02-2020 11:49 PM
ChristopherVan_de_Wyngard
For some reason since today I have not been able to generate a single feature report from Survey123, it give me an error "Internal server-side error" every single time.
I have generated the same report yesterday just fine but no luck today.
AprilChipman
I received this error this morning also. No previous issues on surveys and Make scenarios that were working yesterday.
Geotechnickal
Also running into this error on our Survey123 Portal accounts on all surveys.
Tags (1)
JamesTurner2
Getting this error today as well with enterprise 10.9.1
Hoping that @ZhifangWang might have some insight since they provided help on the original issue.
nnolasco
Exact same issue here.
lmendez_sp
Same version, same issue.
Tags (1)
HarmondSantos1
Started getting this error too since 15:00 NZST yesterday (10/09/2024). Reports were still generating hours before. We're on Portal 10.8.1
DPU-SMAMUS
Same issue here, im from Porto Alegre, Brazil. The error appeared since 09/09/2024, only on the enterprise
nnolasco
I did get word from the analyst I was working with that an update was made Sep 10th, 2024.  They have logged the defect, but no word on a resolution yet.    https://doc.arcgis.com/en/survey123/get-started/whatsnewsurvey123.htm
JamesTurner2
Thanks, I also heard this. There is some action over here: https://community.esri.com/t5/arcgis-survey123-questions/internal-server-side-error-reports/td-p/133...
"Tech Support has logged BUG-000170665 for this."
