Inbox managment
1283
10-29-2020 12:39 PM
CédricVilleneuve
Hi everyone,
I've set an inbox base on a where clause "open/close" to filter the data. I updated a survey on the field and sent it. Back to the office I looked to the feature service on AGO and I can see the modification but when I go back to the inbox, there is no modifications even if I refresh the survey. So what I'm I doing wrong...
Thanks folks
Alber_Verster
Hi Cedric,
One possibility is that the sent survey is still in your Sent box. This would only be possible if you enabled the Sent box but could be the cause.
This is mentioned in the post below:
Prepare for editing existing survey data—ArcGIS Survey123 | Documentation
If you did not enable the Sent box, then your filter could be the cause.
Regards
Alber
