In Web Form in Edit Mode, Map Not Centering on Geopoint
2571
8
11-17-2023 10:23 AM
m3
With newly updated or published surveys, when you open the web form in edit mode, the map centers on the location that you have set in your map in Connect, not at the geopoint of the selected asset.  The lat lon fields show the correct lat lon, and the pin is indeed on the geopoint, however the map is centered on the default location.
I have tested this with multiple surveys, multiple browsers, multiple platforms with the same result.
I have tried setting the default answer to null as well as a dozen other things and get the same result.
I downloaded the latest version of Connect yesterday, this occurs in AGOL and our Portal
ZhifangWang
Hi @m3 ,
The fix to this issue has been deployed to the production Survey123 website, you can test the fix as the same way you used to.
In the future, if you need to test your survey in ArcGIS Enterprise with the Beta Survey123 website, you can use the ?portalUrl=<yourPortal> URL parameter. For example, https://survey123beta.arcgis.com/share/<surveyId>?portalUrl=<yourPortal> . In case this helps, you can find a full list of parameters that are supported by the web app in this help topic: https://doc.arcgis.com/en/survey123/get-started/integrate-launchwebapp.htm
IsmaelChivite
Esri Notable Contributor
@ZhifangWang  This looks like a regression in 3.19. I can repro:
Anyone not using version locking or publishing a new survey will observe this incorrect behavior.
Kudos to @m3  for finding this.
ZhifangWang
Thanks for the feedback.
The team is working on a fix to this issue. Before the fix is applied to the 3.19 web app, please notify the user to pan around/zoom out the map to check the submitted point before making an edit to the survey.
ZhifangWang
Hi @m3 ,
A fix to this issue has been applied to the Survey123 Beta website, you can test it by using https://survey123beta.arcgis.com/share/<yourSurveyId>. Please let us know if you still observe any issues.
The fix is planned to deploy to the production website early next week.
m3
How would I test this in edit mode in our enterprise portal?
ZhifangWang
Hi @m3 ,
m3
It appears to be working.  Thanks for the quick fix!
Vegard_Sulebakk
Hey @ZhifangWang@IsmaelChivite
I am still experiencing this issue in both the latest release version and the beta version.
I can't see anything regarding this issue in the latest change notes?
ahargreaves_FW
I tested this via the beta site and am still experiencing the issue whereby a calculated geopoint fails to center the map...
