If() statement in repeat section, integer question's 'calculation' column not functioning
2145
04-28-2022 09:35 AM
archeomason
Hello, community -
I hope someone might be able to help me troubleshoot a conditional formula in an integer question's 'calculation' field. The field is inside a repeat and the formula's condition references the repeat record's position(..).
For context: I've developed a form where the user records different soil strata as they dig. The attributes of each of these strata (color, consistency, observations, etc.) are recorded in a ${SoilLevel} repeat. The user records the top and bottom depth of each of these strata (see below).
I'd like the form to fill in each level's Top Depth (${SoilTopDepth}) automatically with "0" for the first level (${LevelNumber}) and the previous level's Bottom Depth (${SoilBotDepth}) for all levels after that.
The formula I'm using in the ${SoilTopDepth} field's "Calculation" column isn't populating the field on the form:
if((position(..)=1), 0, (once(max(${SoilBotDepth}))))
For broader context, here's a screencap of the relevant section of the XLSForm:
Can someone point out what I might have wrong?
Also, I was curious if my calculation formula for the ${LevelNumber} field (once(count(${SoilLevel}))) might work better if it were replaced with position(..). Just curious about that one...
Thank you in advance!
DougBrowning
MVP Esteemed Contributor
I did this using max trick like this
This is a soil pit form.  We do share our forms out to the public if you just want mine.  Just pm me.
Hope that helps
DougBrowning
Hope that helps
archeomason
Thank you very much, @DougBrowning! I will try that out. And I just may take you up on your offer!
archeomason
That worked like a champ! Thank you very much.
For what it's worth, I did have it working using the indexed-repeat() function, where it would populate from the previous record's (position(..)-1) bottom depth, but I had this warning prompt saying I had a circular reference that might cause errors in calculations. So I was trying to find a better option.
Yours seems to work great. Thank you very much, sir.
