How to track number of data entries to Survey123
453
05-08-2025 02:00 AM
RachelS
I have about 50 Survey123 forms linked to Enterprise and Portal.
I have to report on the number of data entries to Survey123 a couple of times a year.
Does anyone know how I can do this without having to manually count them in each dataset?
I see Enterprise under Organisation > Status  has a Dashboard section, within which I can select the time period but I can only filter it down to the number of feature services, without it showing the number of records added within the time frame. There is also a Report option of items but again it doesn't give the number of records added.
Thanks
Rachel
ZhifangWang
Hi @RachelS ,
If your report is using PDF or Microsoft Word format, you can achieve this by printing a feature report. Assuming your feature layer name is layer1 and the object ID field is objectid, the syntax ${layer1 | stats:"count,objectid"} will output the record count in the input to the report from the layer. (${layer1 | where:"1=1 !important" | stats:"count,objectid"} will always output count of all records in the layer)
Some links may help:
DougBrowning
MVP Esteemed Contributor
A ArcGIS Dashboard would work well for this.  https://www.esri.com/en-us/arcgis/products/arcgis-dashboards/overview
Neal_t_k
Why not create your own dashboard for this?
RachelS
Thanks for the suggestions.
I was thinking that going down the dashboard route would be the easiest, although it will be one indicator per dataset.
I'll look into the feature reports also.
Neal_t_k
You could use Arcade to aggregate fields from all your tables to one...
