How to integrate custom vector tile basemap in survey for online use?
1219
06-13-2019 12:29 AM
deleted-user-7uHihdbjutPY
Hi all,
i created a survey and need to add a custom base map (vector tiles). The idea is that users open the survey via a link or QR-code on their handhelds and have the self-build basemap displayed in online mode. Is there a way to get this done with AGOL and survey123 connect?
I searched the net but haven't found a solution yet. Any advice is highly appreciated!
Thx
JamesTedrick
Esri Esteemed Contributor
Hi Christian,
At this time you can set the base map in the Survey123 web designer by adding the map to your organization's basemap list.  See Configure map—ArcGIS Online Help | ArcGIS for more information.
