How to I hide existing feature service fields?
2756
03-01-2018 11:58 AM
MatthewMcBurney
I have an existing feature service that I am using in a survey. I have the feature service all lined up and is working. However, I would like to "hide" the CreationDate, EditDate, GlobalID fields in the survey. I have the fields "hidden" in the ArcGIS Online Item and they are not referenced at all in a survey question.
Any advice on how I can hide them in the survey Inbox?
MatthewMcBurney
This worked perfectly - Thank!
RobertBorchert
Honored Contributor
Either turn them off in your MXD and republish the service or go to your Web Map and configure pop ups and turn them off there
MatthewMcBurney
That was done however it doesn't get reflected in the Survey
