how do I provide a default value based on a response to a previous question
10083
6
06-22-2017 04:45 AM
DfIRivers
I have a survey that contains a "select_one" where I use a choice list to pick a code.
I then have a subsequent field which I want to populate with a default value based on the previous response, but I want to have the option to overwrite the default value presented.
Is there a simple way to achieve this?
Tags (1)
JamesTedrick
Esri Esteemed Contributor
A lookup can be done with an if statement with the values inline; additionally the pulldata() function can look up values from an accompanying CSV file - see Formulas—Survey123 for ArcGIS | ArcGIS (Working with External Content)
JamesTedrick
In Survey123 terms, what you are asking for is to calculate a value based on a previous question.  You can do this in the calculation column - see Formulas—Survey123 for ArcGIS | ArcGIS .  A calculation will still allow a value to be manually overridden.
DfIRivers
Hi James,
so... I don't want to e.g. multiply the answer to a previous question by a factor.. I want to use the answer to the previous question to provide a look-up.  Would this be achieved using an a nested if statement in the calculation field?
JamesTedrick
Jing_Sun
Hello James,
When populating answer of a select_one question (Q2) based on answer of a previous question (Q1), a 'recalculate' button appears for Q2 when user select an option in Q1 except one that used to populate Q2.
In the example below, Q2 has this statement in the calculation: if(selected(${question1},'option1'),'option1',''), and Q3 is using pulldata() to achieve the same functionality, they both work for my intention. i.e. Select option 1 in Q1, then Q2 and Q3 will have option 1 selected automatically.
Bur if I select option 2 in Q1, the 'recalculate' buttons appears for Q2 and Q3 no matter what I select.
Am I doing something wrong or will I be able to disable those buttons in the setting?
Many thanks.
Cheers,
Sun
JamesTedrick
Hi Jing,
You're not doing anything wrong- your calculations are working exactly as designed.  Remember that a calculation *must* return a value; there isn't a 'leave everything just as it is' concept.  In this case, when you select option2 in q1, you are calculating q2 to an empty value; the recalculation symbol showing when another value is present reflects that.  Similarly, an empty search would also be calculating q3 to an empty value.
Jing_Sun
Hello James,
Thank you for your helpful information!
Cheers,
Sun
