Hi, does anyone have an update on the Python script to download the survey123 data?
2774
12-05-2016 02:08 PM
DanielCruz1
Hi, I have been trying to use this script in Python without being successful, I would like to know if someone can assist on this or if someone have a working script that has been updated. Thanks
JamesTedrick
Esri Esteemed Contributor
Hi, I've posted the current version of the script I've been working on at http://www.arcgis.com/home/item.html?id=554fbefb325a4db488a24b0db4e99519 .  I've done some fixes for errors I was able to reproduce; please try and if there are issues, provide feedback.  Thanks!
James
WengNg
Hi James,
Will the script also sync records with only their attributes updated? This can be through users updating their collected data through AGOL after submissiong from Survey 123.
Weng
JamesTedrick
Hi Weng,
This script follows the Survey123 capabilities, which is currently add-only.  It will not revise existing records, only migrate the new ones into the database.
