Have a visible field that keeps a tally of how many surveys have been submitted
517
11-22-2023 08:50 PM
j-bromp
Hi there,
Wondering if it's possible to have a field displayed in the survey which shows what number survey it is?
For example if I go out into the field and submit a survey, the next time i go out i would want this field to display '2', and so on.
In addition to this, I am wondering if it is possible to have this field be relevant to another field. For example when i go into the field, i select from a drop down list what the project number is for the site i am visiting. Is it possible to have survey123 record what number survey this is for that particular project number?
Cheers
abureaux
MVP Frequent Contributor
Have a look at pulldata(@layer). Specifically, querying a feature layer.
Be aware that once you pulldata, it is "static". Meaning, you won't see if someone submits a survey right after you finish your query.
