Geopoint within a repeat causes sticky select_one / select_multiple
1038
06-21-2018 12:51 AM
ShanonLoughton
Hi, Geopoints within a repeat cause further/later items within the repeat, such as select_one and select_multiple types to not clear when adding a new repeat. It is probably related to Geopoint types themselves not clearing between repeats, which is probably a known bug?
Versions:
Survey123 Connect 2.6.4 - 2.8
Survey123 for ArcGIS 2.6.7 - 2.8
OS: Windows 10 64bit
See attached survey example.
- Shanon Loughton (Esri Australia)
ArcGIS Enterprise on AWS, Azure & Google Cloud Professional
JamesTedrick
Esri Esteemed Contributor
Hi Shanon,
We believe we have resolved this issue in 3.0.  Can you try a beta version of the release via the Early Adopter Community?
