Geopoint map full extent in grid-theme
1720
07-23-2019 04:19 AM
deleted-user--2hDb5YTmQS1
Hello,
I've created a survey for a tank inspection using the new grid-theme. Unfortunately, the map that depicts the location of my tank doesn't use the entire map space that is available in the second column of my grid.
Is there a way to extent the map to the full extent available?
Thank you very much, best regards,
Jürgen
by Anonymous User
Not applicable
Hi Jurgen,
This is a known issue with geopoint questions and grid theme format, and something we are looking at addressing in a future release. For now, in 3.5, there is no way to make the size of the geopoint question in grid theme fill the entire space it is allocated.
Phil.
BrettStokes
Hello Jürgen,
As of 3.6, you can now manually control the height of map questions, text questions using the multiline appearance, and image questions using the signature appearance. While this will not make your geopoint question automatically fill the grid cell, you can at least set the map to a preferred height value. This is achieved by using a height parameter in the body::esri:style column. See the documentation for more info.
Brett
