Full Name Input - Capitalize Each Word
1772
02-23-2022 08:58 AM
SarahLavin
I am trying to create a single question field to enter in a person's full name. I want to make it so that Survey123 automatically capitalizes the first letter of each part of the name (first name, middle name/middle initial, last name, and any suffixes [English Proper]). How would I go about doing this? Will this be a input mask or a regex formula?
Thanks in advanced!
Katie_Clark
MVP Regular Contributor
Looks like you can probably do this with an input mask
You could also do this with a JavaScript function to convert whatever the input is and return the Title Case name in a new field.
Hope that helps!
-Katherine
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
