File question type with Multiline appearance not working for Inbox surveys
3092
11-16-2024 12:54 AM
PanjiBrotoisworo2
I've noticed an issue in my form where I can only using the file question type if I'm creating a new response in my survey I can use the File question with multiline appearance. I use this for batch uploads which is very important since our field staff commonly upload more than 50 images at the same time.
However, if i set it to an Inbox method and load a pre-filled form via an Inbox. The paper clip button to batch upload files will be missing.
I've rebuilt the form using Survey123 Connect 3.21 (was previously using 3.18) but the issue is still present.
I've tested this on both my Android and iOS device. However, filling the inbox form on Survey123 on the Windows PC doesn't have the same issue and i can use the batch upload feature.
ChristopherCounsell
MVP Frequent Contributor
ChristopherCounsell
