Feature Report with Multiple Geometries in a Map
1060
04-25-2023 09:19 PM
jhipolito_GHD
I have S123 form where I have collected a polygon (parent group) and multiple lines (repeat group).  Is it possible to show them all in a single map frame in a feature report?
IsmaelChivite
Esri Notable Contributor
I am thinking you could create a web map including all the layers and then make the map in your report PDF use that web map.
jhipolito_GHD
This is the workaround that I did but if an area is surveyed multiple times data in the webmap would to be filtered to show only the latest features.
