Failed to publish Error 400
1481
03-30-2021 01:09 PM
TonyDaSilva1
Having issues publishing with repeats in Survey123 Connect 3.12.230 & 3.12.232.
I tested with a basic repeat, nothing special. looks like it is having problems creating the relationship table.
code": 400,
"details": [
"Introducing FOREIGN KEY constraint 'REL_FK_service_999999999999999999999999999_DEFICIENCIES2_1' on table 'service_999999999999999999999999999999_DEFICIENCIES2' may cause cycles or multiple cascade paths. Specify ON DELETE NO ACTION or ON UPDATE NO ACTION, or modify other FOREIGN KEY constraints. Could not create constraint or index. See previous errors.
Cheers,
Tags (1)
ZacharySutherby
Hello @TonyDaSilva1
Are you trying to publish to ArcGIS Online or an ArcGIS Enterprise Organization?
Thank you,
Zach
Thank you,
Zach
TonyDaSilva1
Hi Zach, ArcGIS Online.
