extract value from repeat based on maximum value of other attribute
497
07-13-2023 08:38 AM
ChristopherDawe
I have a repeat to collect information relating to boreholes dug at a site (${bhID}, ${depth}, ${concentration} etc).
outside the repeat have created a new field called ${Max_conc} with the calculation set to max(${concentration}), however i would like to know which id and depth this relates to for my report so i can write something along the lines of
"The maximum concentration of ${Max_conc}ppm was found at ${bhID_Max_conc}, with a drilled depth of ${depth_Max_conc}"
I am struggling with how to get the fields of ${bhID_Max_conc} and ${depth_Max_conc} calculated from the repeat entry with the maximum concentration.
Is this possible?
@JamesTedrick @IsmaelChivite
