Error code Publishing error in Survey123 Connect: "code: 400 [Exception has been thrown by the target of an invocation.",
1689
05-03-2017 02:17 PM
AmyRoust
This error took me a while to resolve, so I thought I'd throw it out as a discussion item so that anyone else with the issue had a resource. The message occurred when I was trying to publish a survey from Survey123 Connect. Here's a screenshot:
capture
As it turned out, I was using EDITOR as a name for one of my fields. That isn't in the list of reserved keywords, but when you try to publish, it will generate this message. Took me a while to troubleshoot, but renaming it EDITOR_1 fixed the problem.
If you encounter other error messages and their solutions, feel free to add on to the discussion!
Tags (1)
JohnathanHasthorpe
Thanks for this information - we will add the following fields to the reserved keywords list in the advanced template:
Editor
Creator
EditDate
CreationDate
