Error code 400 "where' parameter
1575
08-31-2020 08:59 AM
MichelleWilliams1
ArcPro and Survey123 Data in AGOL won't connect to the first page of my survey, but the repeat shows up.
The data is still there because I can download it from AGOL.
Friday night I added 20 new fields to my survey and now I get this error.
Let me know if you've seen this, and how to fix it.
James Tedrick‌
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Michelle,
This might be best addressed by opening a support ticket with Esri Support.  Does the data show up in ArcGIS Online Map Viewer or Survey123 Data Tab, or does it not show there as well?  If the data does show up, it seems this might be an issue only with ArcGIS Pro; otherwise, there might be an issue with the configuration of the feature service.
MichelleWilliams1
The answer was that I had dashed in the name.
