Error 500 when removing a question from Survey123 web designer
871
11-26-2025 09:23 AM
JuanTomásMartinez17
Hello everyone,
I’m experiencing an issue with Survey123 and would appreciate any guidance.
Here’s the situation:
  • I created a new survey using Save As from an existing survey.
  • After configuring the new survey, I published it successfully.
  • Later, I made some adjustments by adding new fields and republished without any problems.
  • The issue occurs when I try to remove a question. After removing it and attempting to publish, I receive the following error: "500: Field name 'keywords' does not exist"
I’ve checked the related feature layer, and editing is enabled. I also reviewed the network traffic logs but couldn’t find any additional details about the error.
Thank you in advance
Philip-Wilson
Hi @JuanTomásMartinez17,
What is the question type you are trying to remove? Does this error happen for any questions types you try to remove, or just a specific one?
Regards,
Phil.
JuanTomásMartinez17
Hey @Philip-Wilson
We ended up taking this to a Tech Support case and created the BUG-000181306.
Thank you for reaching out!
Juan.
