I have a survey with repeats that has the bind::esri:parameters set to allowUpdates=true which allows the field technician to edit his repeats. But I am getting an error when going in that feature service and trying to make edits to that repeats either in the web version of survey123 or bringing the feature service into ArcGIS pro. Is there a good way to edit the repeats?
Hi Jeff,
What error did you receive and how do you set up your survey and feature service? Is it on portal?
It is on AGOL, the feature service is set up with full editing permissions. I tried to edit through the survey123 data tab on agol and also bringing the feature service into arcgis pro. This is what I get in Pro
I don't have any domains set up for that field
I also logged in as the survey owner and an admin and was able to update the table on the web form, but I am the only one who can make edits to the data. Is there a certain role that I should be using for the project manager to be able to QC and update the survey123 data after it has been collected? Or do I need to give the ownership over to the project manager?
Hi Jeff,
Could you share your XLS form for us to check further here?
Sure, what's the best way to do that
You con can email to [email protected] directly.
Thanks, just sent
