Dropdown Default
1605
10-23-2017 07:42 AM
JohnMcConalogue
I have a drop down in a survey and I want to set one of the values as a default when the survey opens first.
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi John,
You can do this by supplying the name of the choice you want to be default in the 'default' column in an XLSForm.
JamesTedrick
Hi John,
JohnMcConalogue
Thanks for the reply James.
If I wanted to change the default periodically I will need re-publish the survey.
Just wondering if this will overwrite any data I have captured already?
JamesTedrick
Hi John,
Yes, changing the default will require republishing.  So long as questions are not added or question types changed, the survey data will not be overwritten.
JohnMcConalogue
Thanks for your help James.
I tried this out and thankfully the data was not overwritten.
