Is it possible to disable the Outbox and Draft folders in the field app? There are workflows in which you don't want to let people to change the data by selecting these options instead of sending the survey.
Regards.
This is on the survery123.arcgis.com website also. Can change to Add only I think will work for you.
It was always in "Only add new records" but when I submit the survey the "Send to Outbox" is still available.
Regards.
