Creating sum from dropdown
1490
12-29-2021 02:51 PM
godofsix
 I'm trying to create a sum field using the input from a drop down. I have a form where individuals are asked of the age and I would like a field that will hold the sum of the various age ranges (0-17,18-29,29-30 etc). I tired doing this in Survey123 Online but the calculation is not active
Katie_Clark
MVP Regular Contributor
Is the question within a repeat? Is this what you're trying to do?
https://support.esri.com/en/technical-article/000021664
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
godofsix
Looks similar but my intention is something like this: If age = 0-17 then field 0-17 should hold the total/count entries for 0-17: Same for if age = 18-19 then field 18-19 should hold total/count entries for 18-19.
Katie_Clark
Would the "count" function do what you need?
https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformformulas.htm
Best,
Katie
godofsix
I tried that in Survey123 online but the calculate didn't work. Let me try in the xlsform
