Conditional question options
1888
01-20-2023 09:21 AM
tigerwoulds
Running Survey123 Connect.
I have two questions both select_one from lists.
List one: Group_A, Group_B, Group_C
List two: Viewer, Editor, Publisher
If the user selects Group_A for question #1, I want question #2 to show Viewer, Editor, Publisher
If the user selects anything other than A for question #1, I want question #2 to only show Viewer, Editor.
Can this be done?
Katie_Clark
MVP Regular Contributor
I recommend reading this blog post, I think it should give you all the info you need! (choice filters and cascading selects)
https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-choice-filters/ba-...
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Best,
Katie
tigerwoulds
Excellent, thank you!
I ended up using regex(skills, ${skill}) and it worked like a charm.
