Compare a value in a repeat (int) with a previous value in the same repeat
1872
11-21-2021 01:16 AM
newwollyka
I have a form with a repeat that capture the information of apartments in a building. One of the information captured is the floor number of the apartment in the repeat.
Since the enumerator should start from the highest floor to the lowest one, I want that when the enumerator entered the floor number in each repeat to compare it to the floor number of the previous repeat since it should be less or equal (but not more).
Is there a way to do that?
ZacharySutherby
Hello @newwollyka
You can use the indexed-repeat() function to obtain the value of the floor from the previous repeat and use a constraint to ensure the value entered is less than the previous value.
I've attached a sample XLSForm that shows one way to implement the workflow. Please see this link for more information on formulas in ArcGIS Survey123.
Thank you,
Zach
ZacharySutherby
Hello @newwollyka
Thank you,
Zach
