Change Publishing Setting Defaults in Connect
931
11-26-2024 06:46 AM
mattkramer
Hello,
I was curious if it was possible to update organization settings when publishing to ArcGIS Enterprise. Specifically, the setting called "Use global ID parent keys in repeat relationships". When connected to ArcGIS Online, this is defaulted to yes, while when connected to ArcGIS Enterprise, it is defaulted to no. I would like to change this default in Enterprise to yes.
abureaux
MVP Frequent Contributor
I don't believe this is an Organization setting. You need to specify it in the "Options" within Connect during publishing.
abureaux
mattkramer
I think you are correct, thank you for the confirmation. I posted an idea to recommend this get added. Linked below:
Organization Setting to manipulate default publish... - Esri Community
