Cannot type in lat/long into map when offline
868
06-04-2019 08:59 AM
DougBrowning
MVP Esteemed Contributor
I just found from the crew that if you are offline you cannot type in custom lat/longs into the little map.
Why?  How can my crew use the type in feature offline then?  Would a tpk help?
Thanks
JordanMiller4
I believe the search function is referencing the ESRI geocoding services so you'd have to be online. I believe you can add your own geocoding service. Maybe something to google and see what others have done.
DougBrowning
Yea but I do not want to geocode i just want to type in a decimal degrees lat/long.  I should be able to at enter that as text.
JamesTedrick
Esri Esteemed Contributor
Hi Doug,
Currently you cannot enter the manual entry mode of the map when offline and there is not a TPK.  Have a TPK (even if only a few levels) will enable entry.
