Can't generate reports or export data
13224
24
01-24-2018 02:43 PM
ChrisShuck1
Every survey my company has created is currently experiencing the same issue. We get the following error when trying to generate reports:  "An error occurred while generating report. get errors when rendering the template: The tag "field_35" should be the only text in this paragraph The tag "field_20" should be the only text in this paragraph The tag"... and so on.  We also cannot export excel files.
JamesTedrick
Esri Esteemed Contributor
Hi Chris,
Can you provide the XLSFile and DOCX file for the surveys that are not working?
ChrisShuck1
Hi James,
They are attached.
Chris Shuck
Staff Biologist
Transcon Environmental
1942 University Avenue, Suite 206
Berkeley, California 94704
ChrisShuck1
Hi James,
I am checking in to make sure that you received the files that I sent you on Monday. I just tried to generate reports from the two surveys in question, and I am still getting the error messages.
Chris Shuck
Staff Biologist
JamesTedrick
Hi Chris,
Yes, I have received them and will look into the issue.
ChrisShuck1
Thank you
Chris
ChrisShuck1
I am checking in. Reports for these two surveys still will not generate. Given that the error message lists no reasons for the error, there is little that I can do to fix this issue on my own.
Chris
JamesTedrick
Hi Chris,
Apologies for the lateness of a response.  It looks like the form is sufficiently long enough that part of the data is being cut off when submitting for printing.  I've logged an issue to support a submission method that can handle larger surveys.
ChrisShuck1
Oh, interesting. Do you think it will be a while before a fix? Should I go ahead and shorten the surveys for now? If so, do you know what the line limit is?
Chris
JamesTedrick
Hi Chris,
Eat the earliest, a fix would likely be in late March.  It isn't a specific line limit per se, but rather a total data limit - your Artifact Survey, with just a couple of sections filled in, is about 10KB of data.  Given the other information being submitted, it looks like it would need to be about 2/3 as big as an initial guess.
by Anonymous User
Not applicable
Chris,
I had the same problem but when I cleared my web browsers cache/history (using Chrome) it cleared the problem up for me.
Hopefully this works for you/ is an option for you!
Best,
Allison Zandarski
Environmental Health Program Coordinator
